Onjai
How do I copy a row of selected data from one table to another using jsl?
Trying to use jsl script to copy a row of data that was selected from a fit y by x and paste that to another table (BigClass2).  Using the Big Class table,  Oneway Analysis of height By name, I select one point on the chart which selects the row in the table.  I can get the row number but cannot find how to copy the selected cell values.  Searched forum and did not locate a solution.
Any help would be appreciated.
dt = Data Table( "Big Class" );
dt2 = Data Table( "BigClass2" );
sel = dt << Get Selected Rows;
Re: How do I copy a row of selected data from one table to another using jsl?
Make the subset invisible, then delete it when no longer needed.
dt = Open( "$sample_data/Big Class.jmp" );
dt2 = subset( dt );
dt << select rows( {2, 4, 6} );
dt3 = dt << subset( Selected Rows( 1 ), Selected columns only( 0 ),invisible );
dt2 << concatenate( dt3, AppendToFirstTable( 1 ) );
close(dt3,"nosave");
Here's one approach using data table subscripting (needs JMP 13); it depends on the table columns being identically ordered.
dt2 = subset( dt );
sel = dt << Get Selected Rows; // [2,4,6]
seldata = dt[sel, 0]; // {{"LOUISE", 12, "F", 61, 123}, {"J...
oldend = N Rows( dt2 ); // 40
dt2 << addrows( N Items( seldata ) ); // add 3 rows to end
// copy the seldata to the end, one after the old end
dt2[oldend + 1 :: oldend + N Items( seldata ), 0] = seldata;
Here's an approach using concatenation:
dt2 = subset( dt );
dt3 = dt << subset( Selected Rows( 1 ), Selected columns only( 0 ) );
Onjai
Hi Craige,
Thank you for the quick reply.
The columns are identically ordered.  Using JMP 11 so the data table subscripting does not seem to work. See screenshot below.
The concatenation script opens a subset table which I do not require.  I have 2 tables open, one table generates a chart.  From this chart I select specific points that are to be copied to another table.  I will be selecting a single data point and then run the script to copy the data over the the table.  Then select another point and run the script.
Onjai
This time with the screenshot.
dt2 = subset( dt );
Onjai
This worked.
Thank you very much!
