matt7109
Center values in cell
Is there any way to center character values in a cell? Natively, charcter values are left aligned, but I would like them centered in a certain column.
Thanks!
Re: Center values in cell
There is not a setting that will Center values in a data table.  Formatting is a Column wide function, not a cell based function.  However, in JMP 13, you can create a custom format which you might be able to use if you can identify the specific values you want to change, and then possibly center the values.
