kk
kk
How do I change a JMP Journal Filepath?
Hello! I like using JMP journals, and I frequently work in areas that have spotty WiFi, so I save directly to my computer. When I try to share my data with other people, even though they have access to both the data file and the journal, they are unable to execute the scripts in the journal since the filepath is still attached to my computer. How would I change that filepath to enable widespread access?
Re: How do I change a JMP Journal Filepath?
I suggest that you investigate using JMP Projects. You can then pass the project to your colleague and all of the paths will remain
