NagneTE1
How do I add ref lines to multiple Y in scatterplot Matrix?
I have a question about adding ref lines to multiple Y in Scatterplot Matrix.
I succeed to get ref line values.
but, I don't know how to add.
I want to know add ScaleBox to every "Y"s.
For exaple,
//sel_colnames = {"SPK_VOS_TrimCode_Dec", "SPK_RCV_VOS_TrimCode_Dec", "SPK_RCV_VOS_Post_0p5W"};
upper_limit = {10, 1, 15, 0.75};
lower_limit = {-10, 0.5, -15, -0.75};
I want to add upper_limit & lower_limit to the below chart.
Also, I want to adjust Y axis scales for each "Y"s.
//JSL for multiple "Y"s - please give me an advice on it.
dt adress = pick file({"All Files|*"});
dt = Open(
	dt adress,
	columns(
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Comma, CSV( 1 ) ),
		Strip Quotes( 0 ),
		Use Apostrophe as Quotation Mark( 0 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		Treat empty columns as numeric( 0 ),
		CompressNumericColumns( 0 ),
		CompressCharacterColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 0 ),
		Column Names Start( 1 ),
		Data Starts( 47 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
//Delete unnecessary columns
dt=Current Data Table ();
dt << Delete Columns( :"Column 2"n, :"Column 3"n, :"Column 4"n, :"Column 5"n);
dt << delete row( 6 );
// Split dt -> dt(value of test item) & dt_item(upper&lower limit of test item)
dt << select rows({1,2,3,4,5}) ;
dt_item = subset( dt );
dt << delete rows( {2,3,4,5} );
// Replace column names with Test Name (*dt)
For( c = 1, c < N Col( dt ), c ++,
 Column( dt, c ) << Set Name( Column( dt, c )[1] );
// Replace column names with Test Name (*dt_item)
For( c = 1, c < N Col( dt_item ), c ++,
 Column( dt_item, c ) << Set Name( Column( dt_item, c )[1] );
dt << delete rows( {1} );
dt_item << delete rows( {1} );
//Change Data Type to Numeric&Continuous (*dt)
colList = dt << get column names(charater);
For(i=1,i<=n items(colList), i++,
column(dt, colList[i]) << Data Type( Numeric ) << Set Modeling Type( Continuous );
//Change Data Type to Numeric&Continuous (*dt_item)
colList = dt_item << get column names(charater);
column(dt_item, colList[i]) << Data Type( Numeric ) << Set Modeling Type( Continuous );
///Data processing done.
//Select Test Item for Scatterplot Matrix
colDlg = Column Dialog(
	Title( "Test Item Selct" ),
	ycol = Col List( "Test Item", Min Col( 1 ), Max Col(15) ), //
//Read Test Item's Test Number, Upper & Lower Limit
n = N Items( colDlg["ycol"] );
dt_item << Select Columns( colDlg["ycol"]);
sel_colnames = dt_item << Get Selected Columns(string);
show(sel_colnames);
rowNum = 1;
col = Column( dt_item(), colDlg["ycol"]);
test_no = col[ rowNum ];
//Read UL
rowNum = 3;
upper_limit = col[ rowNum ];
//Read LL
rowNum = 2;
lower_limit = col[ rowNum ];
test_no = {};
upper_limit = {};
lower_limit = {};
for(cnt=1, cnt <= n, cnt++,
col = Column( dt_item(), sel_colnames[cnt]);
show (col);
rowNum = 1;
test_no[cnt] = col[ rowNum ];
//Read UL
rowNum = 3;
upper_limit[cnt] = col[ rowNum ];
//Read LL
rowNum = 2;
lower_limit[cnt] = col[ rowNum ];
show(test_no);	show(upper_limit);	show(lower_limit);
//Scatterplot Matrix
stm = dt << Scatterplot Matrix(Y(colDlg["ycol"]), X( :Test Name),
	Fit Line( 0 ),
		Dispatch(
			"1100",
		Dispatch( {}, "Test Name", TextEditBox, {Set Text( "Site #" )}),
		Dispatch( {}, "Scatterplot Matrix Plot", FrameBox, {Frame Size( 500, 200 )} ),
//Close Data Tables without the report.
stm << Journal;
close(dt,"nosave");
close(dt_item,"nosave");
Re: How do I add ref lines to multiple Y in scatterplot Matrix?
At least you will have to abs to abs[x] as currently you are setting all the limits to all axisboxes
cols = {"height", "weight"};
lsls = {55, 80};
usls = {70, 160};
spm = dt << Scatterplot Matrix(
	Y(Eval(cols)),
	X(:age),
	Fit Line(0)
abs = Report(spm) << XPath("//AxisBox");
Remove From(abs, N Items(abs)); // Drop x-axis
For (x=1, x <= N Items(abs), x++,
	Eval(EvalExpr(
		abs[x] << Add Ref Line(Expr(lsls[x]), "Dashed", blue, Expr(Char(lsls[x])), 1);
		abs[x] << Add Ref Line(Expr(usls[x]), "Dashed", blue, Expr(Char(usls[x])), 1);
Here is one simplified example
lsls = {55, 80};
usls = {70, 160};
	Y(Eval(cols)),
	X(:age),
	Fit Line(0)
For Each({ab, idx}, abs,
	Eval(EvalExpr(
		ab << Add Ref Line(Expr(lsls[idx]), "Dashed", blue, "LSL", 1);
		ab << Add Ref Line(Expr(usls[idx]), "Dashed", blue, "USL", 1);
Using Associative Array to store limits might make the code a bit cleaner
NagneTE1
Thank you for your reply.
The example doesn't work in my JMP version 15.
How can I replace "For Each" syntax?
Sorry. I don't know how "For Each" works.
I just replaced For Each syntax with for syntax.
Almost works, but Every 'Y' has the same ref line. (*limit[1] value..)
How can I fix it?
For Each -> For
abs = Report(stm) << XPath("//AxisBox"); //Display Option.
//Show (N Items(abs));
For (x=1, x <= N Items(abs), x++ ,
	Eval(EvalExpr(
		abs << Add Ref Line(Expr(lower_limit[x]), "Dashed", blue, "LSL", 1);
		abs << Add Ref Line(Expr(upper_limit[x]), "Dashed", blue, "USL", 1);
*result
Thanks
lsls = {55, 80};
usls = {70, 160};
	Y(Eval(cols)),
	X(:age),
	Fit Line(0)
	Eval(EvalExpr(
NagneTE1
Thanks a lot!!
