Danial1
How do I Increase the gap between each bar graph?
How do I increase the gap between each bar chart so that we can clearly see the labelled values at the top?
Re: How do I Increase the gap between each bar graph?
Right click on the graph and select Customize.
Go to the Bar entry and change the Width Proportion value
Danial1
I'm not sure what happened but my jmp didnt show the same optionDanial1_0-1605807615161.png
Danial1
would it possible to display the labelled values vertically?
There is not an option to allow for vertical labels.  The only way that I can think to do this is to use the "Add Graphics Script" to the graph and write your own values on top of the bars.
