Diana
How could I do batch Wilcoxon Test in Fit Y by X?
Hi Brilliant JMP users,
I have a data-set of same Y and X in comparison, with different methods, at time points and at different measurement position etc. Fit Y to X is used to analyse the data. In the analyse, I put the methods, time points and position in "by". Then I got >30 pair comparison that each all need to do wilcoxon test. I have to click the red triangle and select non-parametic->wilcoxon in each comparsion for >30 times. Are there any way we could do batch process?
I tried to understand the saved session script and couldn't understand well. Not yet capable of write script for the process.
Thank you,
diana
Re: How could I do batch Wilcoxon Test in Fit Y by X?
Press and hold down Ctrl (CMD if on macOS) while pressing the red triangle (test also what happens if you hold Alt). This should let you send the selection to all of reports at the same time.
Windows and macOS Keyboard Shortcuts
Diana
Thank you Jthi, the Ctrl shortcut is very powerful! Now I could do distribution check, variation check, comparison analysis in few clicks.
