John_K
Does Control Chart plot data by a timestamp column OR by the way the data table is sorted ?
Does CCB have the ability to "auto-recognize" a timestamp column to order data ?
Or does it plot data simply by the way the data is sorted in the data table (independent of actual timestamp) ?
Re: Does Control Chart plot data by a timestamp column OR by the way the data table is sorted ?
If you do not specify an X axis column, it uses the row order. If you drag a column to the X axis, it will use the values from that column as the order to use
