lala
Level IX
How can use a script to match data directly from a matrix?
For example: Get the memory matrix ar with the following script.
How do match data directly from a matrix with a script?
Achieve something like this:
dt<<Update(With(d2),Match Columns(age=age));
Thanks!
Re: How can use a script to match data directly from a matrix?
One option would be to first use << Get Rows Where to get row indices for age and then Data table subscripting to add the values, but if you don't have to use matrices using JMP's join/update might be faster. So it might be a good idea to create a table from the resulting matrix and then join/update that to the table.
