ckerr
How can the results of summarize be made into a true table like summary generates?
How can the results of a summarize be made into a true table like summary generates?  http://www.jmp.com/support/help/Advanced_Data_Table_Scripting.shtml does not cover this issue directly.
I am trying to group a large data set by year and month, then calculate various percentiles for numeric data.
The goal is a new table of percentiles for each unique year/month subset.
I can use Quantile (<variable>,0.99) to get the 99th percentile in summarize, but not a table output;
I can get a table output from summary, but not the 99th percentile.
The summarize code is:
dt=current data table();
summarize(
a = by(areaname, roomnbr, isoname, Site, year, quarter),
nobs = count(CFU),
nhole = count,
p99 = quantile(CFU,0.99),
p95 = quantile(CFU,0.95),
pmed = quantile(CFU,0.50),
pave = mean(CFU),
ms
Super User (Alumni) ms
Re: How can the results of summarize be made into a true table like summary generates?
It is possible, at least in JMP 11 and I think in several earlier versions, to get percentiles with Summary. There is a text box "For quantile statistics, enter value (%)".
JSL syntax:
dt << Summary( Group( :areaname, ... ), Quantiles( 99, :CFU ) ) );
It is also possible to insert the results of Summarize() into a table, but it requires scripting that may become quite complex if a general solution ( e.g. varying nr of grouping cols and statistics) is desired.
ms
JSL syntax:
