Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
frits_quadt
How can I parse effects to "Fit Model" in a script?
I am trying to pars effects to a fit model in a script.
The effects are generated by a script using several runs of stepwise selection using nominal logistic regression. The selected variable names are outputted to a JMP datafile "final selection.jmp".
This is no problem if only main effects are selected, but I have not been successful in including a two factor interaction.
For main effects only I used the following script:
Basedata=concat( projectpath, "final selection.jmp");
dt = OPEN(basedata);
myparameters = :Parameter << Get Values();
close(dt,nosave);
sdt = Open(concat(projectpath, "all data.jmp"));
UseEffects = {};
For (ii = 1, ii <= NItems(myparameters), ii++,
   colname = myparameters[ii];
   col = Column(sdt, colname);
   InsertInto(UseEffects, col)
Fit Model(
 Y( :Y ),
 Effects( Eval(UseEffects)),
 Personality( "Nominal Logistic" ),
 Run( Likelihood Ratio Tests( 1 ), Wald Tests( 0 ), Confusion Matrix( 1 ) )
Using the same script if an interaction is selected results in an error message "could not find column ..."
I then tried the following script to generate an array with effects:
   position = contains(colname,"*");
   If (position > 0,
   col = ":"||left(colname,position)||" :"||right(colname,length(colname)-position),
   col = ":"||colname);
   /*col = Column(sdt, colname);*/
Although the effect names in UseEffects look ok, this also fails and gives again a "Column not found ... " error.
Any solution is welcome.
Re: How can I parse effects to "Fit Model" in a script?
I think you might need to use JSL expressions for this. Below is an example similar to yours using the Boston Housing sample data table:
myparameters = {"crim*zn", "zn", "indus", "nox", "rooms", "age", "distance"};
sdt = Open("$SAMPLE_DATA/Boston Housing.jmp");
EffectsExpr = Expr(Effects());
	If (position > 0,
		col = ":"||colname
	InsertInto(EffectsExpr, parse(col))
fmExpr = substitute(
	Expr(Fit Model(
	 Y( :chas ),
	 _effects_,
	expr(_effects_),
	nameexpr(EffectsExpr)
eval(fmExpr)
Michael Crotty
Sr Statistical Writer
JMP Development
	If (position > 0,
		col = ":"||colname
	Expr(Fit Model(
	 Y( :chas ),
	 _effects_,
	expr(_effects_),
eval(fmExpr)
Michael Crotty
JMP Development
frits_quadt
Thank you, I have used the solution you described and it did solve my problem.
lazzybug
@michael_jmp Do you know if we can get the effect list from DoE model? Because the effect list was saved in the model when we design the DoE, we don't have to manual generate effect list as mentioned here. For example, how to get the list of Y, and Effects from the model script below? Thank you so much.
Fit Model(Y(:Y1, :Y2, :Y3, :Y4, :Y5, :Y6, :Y7, :Y8, :Y9, :Y10, :Y11, :Y12, :Y13, :Y14, :Y15), Effects(:X1 & RS, :X2 & RS, :X3 & RS, :X4 & RS, :X5 & RS, :X1 * :X1, :X1 * :X2, :X2 * :X2, :X1 * :X3, :X2 * :X3, :X3 * :X3, :X1 * :X4, :X2 * :X4, :X3 * :X4, :X4 * :X4, :X1 * :X5, :X2 * :X5, :X3 * :X5, :X4 * :X5, :X5 * :X5, :Block, :X6, :X7), Personality(\!"Standard Least Squares\!"))
There are at least two options, parsing that function as a string or expression. Below is one option how you could parse it as expression using Arg()
f = Expr(Fit Model(
	Effects(
	Personality("Standard Least Squares")
first_arg = Arg(f, 1);
second_arg = Arg(f, 2);
ys = Substitute(Arg(f, 1), Expr(Y), Expr(List()));
show(first_arg); // first_arg = Y(:Y1, :Y2, :Y3, :Y4, :Y5, :Y6, :Y7, :Y8, :Y9, :Y10, :Y11, :Y12, :Y13, :Y14, :Y15);
show(second_arg);
show(ys); // ys = {:Y1, :Y2, :Y3, :Y4, :Y5, :Y6, :Y7, :Y8, :Y9, :Y10, :Y11, :Y12, :Y13, :Y14, :Y15};
I think you could also use Extract Expr()
Extract Expr(f, Y(Wild List()));
lazzybug
Thank you so much for your help @jthi . I figured it out by myself, but your method is much simpler.
