frankderuyck
Change numbers in easy DOE data entry?
Im am setting up a 3 continuous factor 13 run design in flexible easy DOE. Is it possible to change numbers in the DOE data entry? There are some comma figures I'd like to round off.
Re: Change numbers in easy DOE data entry?
Are you referring to the factor levels in the design? You may not change the design at this time. Only the response values are editable.
frankderuyck
Pity, it would be a help to round off decimal numbers to the nearest axial or centerpoint for my trainings and classes for it is a little stange to present a design point like 25,16 where the center point is 26. So, if not possible no problem I will use custom DOE for reduced run doe's.
