Given the data table
This JSL will produce the required new table
names default to here(1);
// Create a handle to point to the data table in question
dt = current data table();
// Convert the Result column into several columns
// Text to columns
dt << Text to Columns(
columns( :Result ),
Delimiters( "|" )
// Use a multiple series stack to stack the data
dtStack = dt << Stack(
columns( :Result 2, :Result 3, :Result 4, :Result 5, :Result 6, :Result 7 ),
Source Label Column( "Label" ),
Stacked Data Column( "Data" ),
"Non-stacked columns"n( Keep( :Unit#, :Result 1 ) ),
Number of Series( 2 ),
Output Table( "Untitled 20.jmp" )
// Delete unneeded columns
dtStack << delete columns(:Label,:Label2);
// Rename the stacked columns
dtStack:Result 1 << set name ("Number Of Tests");
dtStack:Data << set name("PIN");
dtStack:Data2 << set name("Value");
All of the above JSL was created by running the Text to Columns, Stack and Column name changes etc. interactively, and then going to the JMP log and cutting and pasting the JSL that JMP produced into a script window. I will confess to some cleaning up of cut and pasted JSL to make it look better.
