Greeny
plotting confidence intervals in JMP "fit curve"
Is there a way to overlay the confidence interval (shaded) with the fitted curve when using the "fit curve" feature in JMP (without JSL)?
Thanks.
Re: plotting confidence intervals in JMP "fit curve"
Doesn't seem like you can add those to Fit Curve platform so you might have to use Fit Y by X platform (or maybe something else).
Greeny
Thanks. As I am trying to fit a sigmoidal curve (3/4/5-parameter logistic), my only options in JMP-Pro are "Fit Curve" or "Nonlinear". Neither of these platforms provides the option of including shaded confidence intervals with the fitted curve.
Hi @Greeny,
If you use the Prediction Profiler in Fit Curve that should have confidence intervals - if you're looking for it in the sections of the Fit Curve platform that is not currently available, might be a good point to add to the wish list.
Thanks,
Ben
Greeny
Thanks, Ben. Yes, I need the confidence or prediction interval around the fitted curve that appears with the data points overlaid. I don't bother with wish lists in JMP because based on my experience, it hasn't been fruitful. For example, even a simple matter of connecting the medians between boxplots in the Fit Y by X platform which I requested several times many years ago has still not been implemented!
Please see this page in the documentation about Nonlinear Platform Options (red triangle). You can save the confidence interval formula and plot it along with the prediction formula in Profiler (Graph menu).
