jan_solo
How can I build a V List Box dynamically?
Hi everyone,
I need a window, that can be saved as Word document.
At the moment the results are completely useless (as there are a few thousand graphs underneath each other on one page).  I figured out why my page breaks don't work.  The problem here is that I have to build the window dynamically.
What I need to do is:
New Window("MyTitle", // Create a new window
    V List Box( // Stack everything on top of each other
        For (i = 0, i <= N Col(InputTable), i++,
            <Do Stuff>;
            <Create Chart>;
            <Do Stuff>;
            <Create Chart>;
            <Add Page Break Box>;
However, the syntax for the V List Box
V List Box(
     <<Element1,
    <<Element2,
This means my code will never work...
I tried to put the for loop outside the V List Box (adding several list box to a window), but then I have no results.  So what I actually need is a way to define a V List Box and a way to add charts and page break boxes to it AFTER it was created and initialized, like this
    MyListBox = V List Box();
<Do Stuff>;
ch = <Create Chart>;
MyListBox << Add ch;
Is there any way that I can add my charts after List Box Creation?
Or is there any wy I can dynamically add charts to the listbox?
Or is there a way to store all charts in an array?
Thanx!
Jan.
jan_solo
Re: How can I build a V List Box dynamically?
InputTable = Open( "$SAMPLE_DATA/Drug.jmp" );
New Window( "MyWindow", tt = V List Box() );
For( i = 2, i <= N Col( InputTable ), i++,
  <Do Stuff>;
  tt << append(
    V List Box(
      Text Box( "Chart " || Char( i - 1 ) ),
      InputTable << oneway( Y( Column( i ) ), X( Column( 1 ) ) )
It works!!!
jan_solo
  <Do Stuff>;
  tt << append(
    V List Box(
It works!!!
