How to do boxplot if both x and y are quantitative variable?
Hi
I am new in JMP, and it may be a simple question.  I would like to do a boxplot (instead of a scatter plot)  with id(y) vs Length(x) (both are quantitative variable).  Somehow I can only choose boxplot when X(length) is categorical variable, I can't find example in help when x is quantitative variable.
Thanks in advance for help.
Kelvin
pmroz
Re: How to do boxplot if both x and y are quantitative bariable?
It's possible to do this in Graph Builder, in JMP 10 and JMP 11.  What version of JMP are you using?
I created a simple table with an X and Y column, where both were quantitative (=continuous) variables.  I was able to click on the boxplot icon to create a boxplot no problem.
Try copying and pasting the following code into a script window, and then hit CTRL-R to run it.
New Table( "Demo Box Plot",
    Add Rows( 13 ),
    New Script(
        "Graph Builder",
        Graph Builder(
            Show Control Panel( 0 ),
            Variables( X( :x ), Y( :Column 2 ) ),
            Elements(
                Box Plot(
                    X, Y, Legend( 3 ), Jitter( 1 ),
                   Outliers( 1 ), Box Style( "Outlier" )
    New Column( "x", Numeric, Continuous,
        Format( "Best", 12 ),
        Set Values( [1, 1, 1, 2, 2, 2, 3, 3, 3, 3, 3, 4, 4] )
    New Column( "Column 2", Numeric,
        Continuous,   Format( "Best", 12 ),
        Set Values( [20.1, 20.3, 18, 15, 17, 34, 65, 45, 34, 54, 34, 12, 24] )
pmroz
    Add Rows( 13 ),
    New Script(
        "Graph Builder",
        Graph Builder(
            Elements(
                Box Plot(
Yes, It works.  Thank you.
Steven_Moore
Another way to do this:  Suppose your X values are no integers.  You can set up a nominal/categorical X variable by defining ranges of the X variable.  For example, let x = 0 - 5 be A, x = 5.1 - 10 = B, x = 10.1 -15 =15, etc.  Then you can do boxplots very nicely.
Steve
