Christina
How can I add (copy) rows according to number in a specific column to the datatable
Hi, I have a datatable as shown below.
The column Anzahl shows the counts of column Prüfplan. I want JMP to make a row for every count so that Anzahl is always 1. I did that manually for row 1 as shown below, to clarify what I want to do. The original row has to be removed of course.
Can anybody help me, thank you!
ron_horne
Re: How can I add (copy) rows according to number in a specific column to the datatable
Hi @Christina ,
Perhaps this tool can help - Expand by Frequency.
https://community.jmp.com/t5/JMP-Add-Ins/Expand-by-Frequency-Column-Add-In/ta-p/21361
 let us know if it works fo you.
The excellent Data Table Tools Add-in created by @brady_brady can do this. Once installed, you'll select the Add-Ins menu, then Data Table Tools, then Reshape Tables, then Unsummarize Rows
ron_horne
Hi @Christina ,
Christina
That's what I wanted, thank you!
The
     Tables=>Join
platform was designed to handle exactly what you are looing for.  Also, take a look at
     Tables=>Update
for another possible option.
Christina
Thanks for your answer, others recommended me the JMP Add-in for expanding tables by frequency, that solved the problem.
