Bradley_Torres
How can I add a second y-axis in graph builder?
Hi everyone!
I´m a recently started JMP user, and I´m now preparing some time profile plots using the ¨Line Option¨ in the Graph Builder. I need to show two different variables with independent y-axes and scales in a single plot, but I don´t know how to add the second axis at the right side. I wonder If can get help on how to do that. Thanks in advance,
Re: How can I add a second y-axis in graph builder?
This is very nicely covered in the Essential Graphing document found in the JMP Document Library under the Help pull down menu.
Bradley_Torres
Hi txNelson. Thanks for your help! I appreciate it! Now I was able to add a 2nd y-axis to my graph! :)
