Zac
Zac
Hover label customizations lost in interactive html export
I modified the hover menu to display name data from two columns in my data table, however when I exported the result of the Distribution script to an interactive html and move the cursor over a data point I only see the default row and value that is in the un-modified hover label.
Can anyone provide some support on how I can retain the customizations in the interactive html export? I am using JMP 16.
Thanks
Zac
ih
Super User (Alumni) ih
Re: Hover label customizations lost in interactive html export
You might consider adding searching and voting for a wish list item for this, or adding one if there isn't one yet.  I don't know of another simple option to do what you are looking for.
