Tavuk89
Hide columns script
I tried this script to hide column no.1,2,3 but it only select the columns without hiding them. What did i missed?
c= dt << Select Columns( [1.2.3] );
c << Hide;
Re: Hide columns script
To hide columns I think you have to hide them one by one so loop over that matrix rather than select the columns.If you have JMP16+ you can use For Each, otherwise change that to "normal" for-loop
col_idx = [1, 2, 3];
For Each({idx}, col_idx,
	Column(dt, idx) << Hide(1);
From scripting index:
Try this
names default to here(1);
dt=current data table();
dt<<get selected columns;
for each( {col}, dt<<get selected columns,
	as column(col) << hide(0)
TaraHaley
Thank you, I tried it and it works for me. I appreciate you, you saved my day. Please mark it as a solution.
Are you also a student like me, and struggling in essay writing? today I am Navigating the academic landscape with CustomWriting Their custom essay writing service, available 24/7, is a lifesaver. From complex assignments to tight deadlines, they handle it all with finesse. Trust me; this service is a game-changer!
