hogi
Level XIII
Check if ODBC data source is available (win)?
I want to check if a specific ODBC datasource is available on a user's computer.
Due to speed issues, I don't want to Create a Database connection but just: see if the datasource setting is available.
Is there a JSL command to get this info?
Re: Check if ODBC data source is available (win)?
Most likely you could use Run Program()  and Get-OdbcDsn (Wdac) | Microsoft Learn.
hogi
Level XIII
Thanks @jthi .
JMP + Run Program -> Powershell is really powerfull.
