Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Created:
Aug 24, 2021 10:32 AM
| Last Modified: Jun 11, 2023 4:17 AM(3412 views)
Hello!
I am looking for a way to add data values to a line graph. I have tried a few options but they have not been conducive to my purposes. I am hoping to get some suggestions for the best way to portray my data.
Example 1 - This graph is from Excel and is what I would like to be able to produce in JMP
Example 2 - My best attempt in JMP at getting a line graph labeled
Hi Jim! Thank you for the response! A secondary question related to that method, if I have two lines on the same graph, the data points double label both lines. I could be applying the labels incorrectly, but is there a way to have them on the same graph and labeled separately?
