GN19
Help with getting data values on a line graph
Hello!
I am looking for a way to add data values to a line graph. I have tried a few options but they have not been conducive to my purposes. I am hoping to get some suggestions for the best way to portray my data.
Example 1 - This graph is from Excel and is what I would like to be able to produce in JMP
Example 2 - My best attempt in JMP at getting a line graph labeled
Thank you!
Gabe
Re: Help with getting data values on a line graph
You need to structure the data differently, and then use an Overlay column
I strongly suggest that you read the Essential Graphing document in the JMP Documentation Library, under the Help pull down menu
Here is my JMP version of your graph
Attached is the data table with the embedded graph
GN19
Hi Jim! Thank you for the response! A secondary question related to that method, if I have two lines on the same graph, the data points double label both lines. I could be applying the labels incorrectly, but is there a way to have them on the same graph and labeled separately?
Thank you!
