Hi @BetaPanda273,
Welcome in the Community !
If you right-click on the table of the Variability Summary report and choose "Columns", you can deselect default columns displayed :
In order to always have some columns hidden, you can maybe script the analysis to only make some columns appear. Example here :
Variability Chart(
Y( :NPN1 ),
Model( "Main Effect" ),
X( :wafer, :SITE, :lot_id ),
Variability Analysis(
:NPN1,
Variability Summary Report( 1 ),
Std Dev Chart( 0 )
Dispatch(
{"Variability Gauge Analysis for NPN1", "Variability Chart for NPN1",
"Variability Summary for NPN1"}, "Std Dev", NumberColBox,
{Visibility( "Collapse" )}
Dispatch(
"Variability Summary for NPN1"}, "CV", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Std Err Mean", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Lower 95%", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Upper 95%", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Minimum", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Maximum", NumberColBox,
Dispatch(
"Variability Summary for NPN1"}, "Range", NumberColBox,
Victor GUILLER
