johnmoore
Help with custom function
hash = Function( {StringList},
	{StringListItem,HashString},
	For( StringListItem = 1, StringListItem <= Length( StringList ), StringListItem++,
		StringList[StringListItem] = Char( Eval( Stringlist[StringListItem] ) )
	HashString = Hex( Blob MD5( Char To Blob( Concat Items( StringList ) ) ) );
This is a hash function that I use to create unique ID's.  The function currently takes a list as it's argument.  I would to have it take one or more arguments separated by commas.  I am hoping to add it to custom functions and make it available to other users.  Thought that would be easier for users if it accepted multiple arguments separated by commas like the Sum() function.
Any thoughts?
Many thanks,
John
3 ACCEPTED SOLUTIONS
Re: Help with custom function
Here is a method using your code that would allow for the entry of some large preset maximum, but variable list of input parameters for your hash function
hash = Function( {a, b = "", c = "", d = ""}, // e="",f=""...…...z="")
	//{StringListItem,HashString},
	StringList = {};
	string# = 1;
	varList = {"a", "b", "c", "d"}; // .........."z"
	While( Eval( Parse( varlist[string#] ) ) != "",
		Insert Into( stringList, Eval( Parse( varlist[string#] ) ) );
		string# = string# + 1;
vince_faller
It might not be exactly what you're looking for but you could just evallist if it's really just a list of strings.
Infinite unknown arguments are easiest with a list.
Names default to here(1);
different_hash = function({StringList},
	StringList = Evallist(StringList);
x = "2";
y = "a";
z = "Expr(b)";
b = "another string";
l = {x, y, z};
show(hash(l) == different_hash(l));
Vince Faller - Predictum
gzmorgan0
@johnmoore ,
This is another variation of @vince_faller and @txnelson 's solutions.
hash = Function( {val1, val2=., val3=., val4=., val5=., val6=., val7=., val8=., val9=., val10=.},
	{i, StringListItem,HashString},
	if(IsList(val1), StringList = EvalList(val1),
		StringList={};
		For(i=1, i<=10,i++,
			Eval( Parse(EvalInsert("If( !IsMissing(val^i^) & IsString(val^i^), InsertInto(StringList, val^i^))" ) ) )
	//Show(StringList);
x = "2";
y = "a";
z = "Expr(b)";
hash(x,y,z);
l = {x, y, z};
show(hash(l), hash(x,y,z), hash( list(x,y,z) )  );  //produces the same result
It would take some documentation/training for your users, that up to 10 string arguments can be entered or use a list if more than 10.
	StringList = {};
	string# = 1;
vince_faller
x = "2";
y = "a";
z = "Expr(b)";
l = {x, y, z};
gzmorgan0
@johnmoore ,
		StringList={};
		For(i=1, i<=10,i++,
	//Show(StringList);
x = "2";
y = "a";
z = "Expr(b)";
hash(x,y,z);
l = {x, y, z};
johnmoore
Many thanks for your solution!
