Group multiple column
I'm novice in JMP. Starting to learn JMP. I'm trying to group a column and count the number of row.
Below is the example to clarify my question.  Basically i have 4 unit tested with different pattern. Each pattern will output failure.
How can i group them based on pattern. Any help will be appreciated. Thanks
Example raw data:
 TEST ATEST A FAIL OUTPUTTEST BTEST B FAIL OUTPUTTEST CTEST C FAIL OUTPUT
UNIT AA0 PATTERNA1
UNIT BA0 PATTERNA2B0 PATTERNB1C0 PATTERNC1
UNIT CA0 PATTERNA1B1 PATTERNB2
UNIT D  B1 PATTERNB3C0 PATTERNC2
Output needed:
A0 PATTERNA12
 A21
B0 PATTERNB11
B1 PATTERNB21
 B31
C0 PATTERNC11
 C21
Re: Group multiple column
The solution is to stack the data and then to use the Tabulate Platform to produce the required output.
Starting with your data table
Go to Tables=>Stack
Fill out the Dialog Box as shown
Click on OK and it will give you the table as previewed
Now go to Analyze=>Tabulate
Drag the Data column to the Drop Zone for Rows
Drag the Data 2 to the far edge of the above dragged Data column and you will have the report you want
GregF_JMP
Hello, welcome to JMP.
The table operations are very powerful and will help in this instance.  The icons on the Table menu items help describe the actions that reshape data.
There are a number of ways to accomplish your objective, but here is one.
1) Your example data should have column headers before moving to JMP, assume First column is called "Part" in upper left cell
  "Copy", "Paste with Column headers" into a blank JMP data table
2) Execute the Table Operation "Stack"  (New in JMP 17, the preview window helps with real time feedback of potential output)
  • Select all Columns except "Part", press "stack columns" button to select six columns with test information to be stacked
  • Check "multiple series stack", set "number of series" to 2
  • De-select "Contiguous"
  • Check "Eliminate Missing Rows" (optional- it's easy to delete the non-failing test items later)
  • Optionally, for non-stacked columns you can "keep all" in case Part/Unit ID will be helpful for other analysis.
  • Press Ok
3) On the table generated by the "Stack" operation, execute the Table Operation "Summary"
  • Select Columns Data and Data 2, Press "Group" button so both columns are listed in the group box.  This will group all combinations of these values. (control-click to select multiple items or do in two steps)
  • Uncheck "Link to original data table"
  • Press OK
Your requested output
Go to Tables=>Stack
GregF_JMP
  • Press Ok
  • Press OK
Thanks
I have tried it works on 3 or 4 pattern.
But when i include all my pattern column around 40++ with it output also around 40++. it will pop up this error.
I tried to make all my column to ordinal or nominal but not able to solve this one.
Any idea why it produce such error?
If you change all of the columns to character, the stack will then work.
