steven_gong
Cols utilities: how to let take care of empty data?
Hi
I got a problem when using Cols->utilities->text to columns.
For example I have data 1, ,2,3, after doing text to columns, I want to get {1},{ },{2},{3} these four columns, while JMP gives me {1},{2},{3} as below screen shot.
Excel can do this with <Text to Columns>
Is there an solution out there in JMP?
The result I got from JMP:
what I expected:
Re: Cols utilities: how to let take care of empty data?
I am not aware of doing what you want with the Text to Columns() function, but here is a simple function that will do what you want
dt = New Table( "Example",
	Add Rows( 3 ),
	New Column( "string",
		Character,
		"Nominal",
		Set Values( {"1,2,3", "1,2,3,4", "1,,3,4"} ),
		Set Display Width( 44 )
newTexttoColumns = Function({dt,x},{defaultlocal},
start = N Cols( dt );
For( theRow = 1, theRow <= N Rows( dt ), theRow++,
	theWord = "";
	wordCnt = 1;
	For( i = 1, i <= Length( Column( x )[theRow] ), i++,
		If( Substr( Column( x )[theRow], i, 1 ) == "," | i == Length( Column( x )[theRow] ),
			If(i == Length( Column( x )[theRow]),theWord = theWord || Substr( Column( x )[theRow], i, 1 ));
			If( N Col( dt ) < start + wordCnt,
				dt << New Column( "", character )
			Column( start + wordCnt )[theRow] = theWord;
			wordCnt++;
			theWord = "";
0;
return = newTexttoColumns(dt,"string");
	Add Rows( 3 ),
		Character,
		"Nominal",
	theWord = "";
	wordCnt = 1;
			wordCnt++;
			theWord = "";
0;
steven_gong
Hi Jim,
What a speed to deliver such a cool script!
Thanks a lot.
BTW, I think JMP may need to consider to enhance the function of <text to columns>.
If you think JMP should have the enhancement, please add it to the JMP Wish List
hogi
Level XIII
I recently had the same issue and wondered if a checkbox can be added to the tool:
Then the user can decide on his own if he wants to enable/disable the feature to treat multiple separator character as a single one:
Text To Columns: handle missing data correctly
