Group Analysis to blanket check bad tools
What is the correct way to blanket check in JMP?
meaning, Y-axis = Yield, X-axis = DateTime, Partition/Overlay by Multiple tools, generating multiple charts with each having partition/overlayed by 1 step's tool to see which tool from each step is the problem
Re: Group Analysis to blanket check bad tools
I'm not sure what you wish to do? Could you provide some example data / graphs / explain in more detail?
