bmallmann
Terneary plot - scale - reverse order
I want to change the scale order. However, the option is not open to do it.
Already tried: I also changed to negative numbers to be in the order I want but then the script don't accept negative numbers.
mixture profiler: allow only formulas
Is there any other solution? for this parameter be more flexible?
Re: Terneary plot - scale - reverse order
If you mean that you want to 'reverse' the scale, that is, 0 to 1 becomes 1 to 0, there is no way to do it. The Ternary Plot is a standard representation of the dependent proportions of three components.
