New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
You need to specify your V11xxx categories as OVERLAY to produce the graph you shared
Right-click on the plot area and ADD a new BAR plot
On the left of the Graph Builder window, locate the new BAR options, click on the red downward triangle, and unselect the OVERLAY for that set of bars only
Change the BAR STYLE to FLOAT
Feel free to share your data table or a mock example data table to enable the creation of a script I could build for you.
