NewbietoJMP
Creating a formula to categorize values by quantile
Advice on categorizing data in quantiles as a new variable.
Solved - thanks!
Thierry_S
Re: Creating a formula to categorize values by quantile
I am not aware of a built-in function that would yield what you need. Instead, I use the formula below to classify my data dynamically into quartiles.
If(
	:DATA <= Col Quantile( :DATA, 0.25 ), 1,
	Col Quantile( :DATA, 0.25 ) < :DATA <= 	Col Quantile( :DATA, 0.5 ), 2,
	Col Quantile( :DATA, 0.5 ) < :DATA <= 	Col Quantile( :DATA, 0.75 ), 3,
	4
I hope it helps.
Best,
TS
Thierry R. Sornasse
My approach is the same as @Thierry_S, but I used temporary variables in the formula for efficiency.
Thierry_S
If(
	4
I hope it helps.
Best,
TS
Thierry R. Sornasse
