Yass
Graph display issue
Hello everyone,
I’m having an issue with my graph display. I selected the line option, but the first column appears as a line while the second shows points, and there’s also an enumeration appearing. Please see the attached image for clarification.
// Créer un graphique de ligne pour "Percent NOK ICT" et "Percent NOK FCT"
graph1 = Graph Builder(
    Size( 600, 400 ),
    Variables( X( :Date ), Y( :Percent NOK ICT ), Y( :Percent NOK FCT ) ),
    Elements( Line( X, Y( 1 ), Legend( "Percent NOK ICT" ), Color( "Blue" ) ),
              Line( X, Y( 2 ), Legend( "Percent NOK FCT" ), Color( "Orange" ) ) ) // Utiliser une courbe pour "Percent NOK FCT"
// Afficher le graphique
graph1 << Show Window;
// Créer un graphique en barres pour "Total ICT" et "Total FCT"
graph2 = Graph Builder(
    Size( 600, 400 ),
    Variables( X( :Date ), Y( :Total ICT ), Y( :Total FCT ) ),
    Elements( Bar( X, Y( 1 ), Legend( "Total ICT" ), Color( "Blue" ) ),
              Bar( X, Y( 2 ), Legend( "Total FCT" ), Color( "Orange" ) ) )
graph2 << Show Window;
// Créer un graphique de dispersion pour "Percent NOK ICT" vs. "Percent NOK FCT"
graph3 = Graph Builder(
    Size( 600, 400 ),
    Variables( X( :Percent NOK ICT ), Y( :Percent NOK FCT ) ),
    Elements( Points( X, Y, Legend( "Scatter Plot" ), Color( "Green" ) ) )
graph3 << Show Window;
Thank you in advance,
Re: Graph display issue
You need to have a separate Elements paragraph for each of the Y variables specified.  Below is an example of the method your code uses which replicates your results, followed by an example using the correct syntax to get what you want.
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Graph Builder(
	Variables( X( :age ), Y( :height ), Y( :weight ) ),
	Elements(
		Line( X, Y(1) ),
		Line( X, Y(2) )
Graph Builder(
	Elements(
		Position( 1, 1 ),
		Line( X, Y, Legend( 11 ) )
	Elements(
		Position( 1, 2 ),
		Line( X, Y, Legend( 12 ) )
dt =
Graph Builder(
	Elements(
		Line( X, Y(1) ),
		Line( X, Y(2) )
Graph Builder(
	Elements(
		Position( 1, 1 ),
	Elements(
		Position( 1, 2 ),
Yass
Thank you !
Yass
I have a question please. Can you help me figure out how to change the bar color ?
In the screen, each parameter shows a color, but the graph displays 2 bars in blue, and the 2 last one being red.
Right click on the bar color in the legend, and select "Fill Color", then click on the color you want.
I strongly suggest that you take the time to go to the Help pull down menu and select JMP Help.  Then in the search line, type in Graph Builder.  There are several links from there for topics that will show you the ins and outs of Graph Builder.
