Level XI
Graph builder - reverse Y scale (only)?
How can I reverse the Y scale in Graph Builder when using Shape files?
Unfortunately,
Graph Builder(
	Size( 545, 458 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( Color( :"Y-Pos"n ), Shape( :Shape_Name ) ),
	Elements( Map Shapes( ) ),
		Dispatch( {}, "", ScaleBox( 2 ), {Reversed Scale} )
doesN't have an effect - and with  hogi_2-1713288717745.png in the GUI the X Scale gets reversed as well
Re: Graph builder - reverse Y scale (only)?
Do the reversing in your shape file an not in graph builder (build it already reversed)
Level XI
I don't think that it will help.
I want "-20" to appear on the Y axis below 20.
But "-20" on the x axis should stay on the left.
Editing the shape fill won't affect the appearance of the plot.
I just tried to use a negative aspect ratio - without success.
Level XI
I submitted a wish to enhance the functionality of Graph Builder.
Maybe others will find the idea useful:
Graph builder + Shapes -> option to flip the map
