GregMcMahon
Graph builder - plotting two x-y lines with selected rows and a third with all rows
Hi folks,
Yes, I know the answer to this will be amazingly simple and so am asking with plenty of egg on my face, but I'm spinning wheels right now. These are actual versus predicted plots, and I want to plot two lines using only validation rows from a validation column (for a neural and a standard least squares regression), as well as the result from the regression with all rows. Thought the answer might be in local data filter with the validation column but no luck.
Thanks and warmest regards,
Greg
Re: Graph builder - plotting two x-y lines with selected rows and a third with all rows
Most likely the easiest options are to either create new column(s) with some missing values or stack your data and plot with that. Below is an example of using duplicate column for x-axis with some missing values
GregMcMahon
Thanks Jarmo - I knew it would be ridiculously simple....
