MDA_2024
Graph additional line on Time Series Forecast Graph
Hello, very new to JMP so apologies for my lack of experience.  I am creating a Time Series Forecast Graph with 95% confidence intervals. What I am trying to do is plot my unit forecast on the same graph to see the comparison.  I've attached my data set.  Conversely if that is not possible, would I be able create the data table used to recreate the chart with confidence intervals in excel?
Thanks for your help.
Re: Graph additional line on Time Series Forecast Graph
What type of plot would you like to see in the end? I'm fairly sure you can plot what you want in Graph Builder but it will require some tinkering with multiple columns in Y-axis and multiple different charts overlaid (not difficult to do in Graph Builder but it can be very annoying)
