terapin
Graph Bulder: Create Multiple Horzontal AND Vertical Graphs
Using JSL I routinely create multiple horizontal and vertical Overlay Plots using the H List Box() and V List Box() commands.  I can see in Graph Builder how to create multiple horizontal line plots but can't seem to figure out how, and if, I can create both multiple horizontal and vertical line plots. Can this be done in GB?
terapin
Re: Graph Bulder: Create Multiple Horzontal AND Vertical Graphs
Thanks MS for the tip,
Unfortunately, I need the individual axes to be independent. I can certainly get them that way by using the H List Box command.  I was just hoping for a more elegant solution using the direct GB interface.
ms
Super User (Alumni) ms
The Group X, Group Y or the Wrap roles can be used arrange multiple line plots vertically or horizontally. However, the different plots are not independent; they share axis settings among other.
Example:
dt << Graph Builder(
    Show Control Panel(0),
    Variables(X(:height), Y(:weight), Wrap(:age)),
    Elements(Line(X, Y, Legend(5)))
For the the wrap role, the layout can be customized by right-clicking on the wrap variable and set e.g. "levels per row".
terapin
XanGregg
It's a feature of small multiples that the axes are aligned for comparison. In cases like these where you want a grid of independent graphs, you'll still need the HList/VList of Graph Builders (turning off the legend) though LineupBox is probably better in either case.
terapin
Xan,
I hadn't heard of the Lineup Box instruction before so I'll take a peek and see how that might be useful.  Thanks for your comment.
