I'm not sure. When I ran your script with the test table. Both graphs are the same, and both can be exported to PDF. In all 4 (?) cases the local data filter is included with the figures.
I messed around with your script a little.
I wrapped the two graphs and the filters in an expression.
When I make the window, I put them directly into the window vlistbox (Lub) by evaluating the expressions there.
Then I prepended (opposite of append, kind of) the text to the top.
After the window was complete I journaled it as the last step. Journals can be a pain to work with so I always try to journal last. Saved the journal as a PDF and then opened it to check to see how it looked.
//dt_source = Data Table( "Wafer_Sort" );
dt_source = Open( "test.jmp" );
set = Expr(
cht_uNV_EC_RD_Set_AfterCyc = dt_source << Graph Builder(
Size( 1029, 643 ),
Variables(
X( :SplitGrp ),
X( :Wafer, Position( 1 ) ),
Y( :Name( "DL_uNV_EC_RD_Set_AfterCyc-DL_uNV_EC_RD_Set_AfterCyc,11510,-" ) )
Elements( Points( X( 1 ), X( 2 ), Y, Legend( 32 ) ) ),
Dispatch(
"400",
LegendBox,
{Legend Position( {32, [-1]} ), Position( {-1} )}
erase = Expr(
cht_uNV_EC_RD_Erase_AfterCyc = dt_source << Graph Builder(
Size( 1029, 643 ),
Variables(
X( :SplitGrp ),
Y( :Name( "DL_uNV_EC_RD_Erase_AfterCyc-DL_uNV_EC_RD_Erase_AfterCyc,11512,-" ) )
Dispatch(
"400",
LegendBox,
filters = Expr(
cht_uNV_EC_RD_Set_AfterCyc << Local Data Filter(
Add Filter(
columns(
:Name( "DL_uNV_EC_Set_PreCyc-DL_uNV_EC_Set_PreCyc,11504,-" ),
:Name( "DL_uNV_EC_RD_Set_PreCyc-DL_uNV_EC_RD_Set_PreCyc,11505,-" ),
:Name( "DL_uNV_EC_Erase_PreCyc-DL_uNV_EC_Erase_PreCyc,11506,-" ),
:Name( "DL_uNV_EC_RD_Erase_PreCyc-DL_uNV_EC_RD_Erase_PreCyc,11507,-" ),
:Name( "DL_uNV_EC_10k_Cycle-DL_uNV_EC_10k_Cycle,11508,-" )
Where( :Name( "DL_uNV_EC_Set_PreCyc-DL_uNV_EC_Set_PreCyc,11504,-" ) == 0 ),
Where( :Name( "DL_uNV_EC_RD_Set_PreCyc-DL_uNV_EC_RD_Set_PreCyc,11505,-" ) == 0 ),
Where( :Name( "DL_uNV_EC_Erase_PreCyc-DL_uNV_EC_Erase_PreCyc,11506,-" ) == 0 ),
Where(
:Name( "DL_uNV_EC_RD_Erase_PreCyc-DL_uNV_EC_RD_Erase_PreCyc,11507,-" ) == 0
Where( :Name( "DL_uNV_EC_10k_Cycle-DL_uNV_EC_10k_Cycle,11508,-" ) == 0 )
cht_uNV_EC_RD_Erase_AfterCyc << Local Data Filter(
Add Filter(
columns(
Where(
nw = New Window( "Reports",
hlb = H List Box(
lub = vlist Box( set,erase )
filters;
lub << prepend( tb = Text Box( "uNV RD_Set & RD_Erase after 10k
tb << Set Font Size( 14 ) << Set Font Style( "Bold" ) << Justify Text( "center" );
tb << set width(700) << set wrap(700);
nw<<journal;
//**** Report *******
Reports = Current Journal();
//Reports << Set page setup( margins( 0.1, 0.1, 0.1, 0.1 ), scale( 0.8 ), portrait( 0 ), paper size( "A4" ) );
Reports << Set page setup( margins( 0.05, 0.05, 0.05, 0.05 ), scale( 1 ), portrait( 0 ), paper size( "A3" ) );
Reports << get page setup();
Reports << SavePDF("debug.pdf");
open ("debug.pdf");
//Close All( Data Tables, NoSave );
Close All( Journals, NoSave );
//Exit();
