dainius
zoom out in graph builder
Hi all,
I am trying to zoom out in the graph builder mode - and have read the instructions.
They say just press ALT key twice or hold it while pressing the zoom key once - et voila, you get the original plot back with the original scale restored.
But it never happened to me! I am tweaking the same graph for 5 minutes now and it is frankly very annoying :).
Do I do something wrong or can anybody help with the solution maybe?
I just want to restore the original graph as it was when created.
Re: zoom out in graph builder
I think it's a double-click of the mouse with the magnifier tool, rather than a double-press of the Alt key.  I am also able to use the Alt + single-click to restore the view, testing with JMP 15.2.  What version of JMP are you using?
If all else fails, you can always right-click on the axes and choose "Revert Axis".  You will need to do this for both X and Y.
ThuongLe
JMP 15.0 works with your suggestion. Confirmed!
Thuong Le
ih
Super User (Alumni) ih
Confirming what @danschikore observed, at least on Windows, using Alt + the magnifier tool seems to reset both axes.  An example:
