drobins
Graph Builder Preferences
In JMP16 when using the Graph Builder the axis settings for numeric continuous linear data type seems to default to "Fixed Dec"  does anyone know how to modify this?  I would like it to default to "Best".  This happens regardless of how to the modeling type is set in the column properties.
In JMP 15 I believe it always defaulted to "Best"?  This is very irritating, I can't seem to find any Preferences that would adjust this.
Thanks
Re: Graph Builder Preferences
I have replicated your issue.  I suggest you submit this to support@jmp.com as a bug.  The Axis setting should be following the format settings for the columns.
