cxu04
Data Preview in Column Formula correct, but values not appearing in Column
I've created a set of columns with a for loop with the below script
For(i=1, i<= N Items(abs_cols), i++,
Eval(
	Substitute(
		Expr(
			New Column(__name2__,
				Formula(
					If(__zscore__ < 2, __abs__)
	Expr(__name2__), "Outliers Removed " || char(abs_cols[i]),
	Expr(__zscore__), Column("Z-score " || char(abs_cols[i])),
	Expr(__abs__), Column(char(abs_cols[i]))
When I run this script, the columns are created with the correct formulas, but no values are filled in any of the new columns. More puzzling is that the Data Preview shows exactly the values as I want them to be filled.
I'm not sure what's going on, please help?
ih
Super User (Alumni) ih
Re: Data Preview in Column Formula correct, but values not appearing in Column
It has to do the function Column() not playing well with column formulas, at last in my experience.  Instead you might try `As Column`, like this:
Names default to here(1);
dt = Open("$Sample_data/iris.jmp");
New Column("Z-scoreSepal length", Numeric, "Continuous", Format("Best", 12), Formula(Random Normal()));
New Column("Z-scoreSepal width", Numeric, "Continuous", Format("Best", 12), Formula(Random Normal()));
abs_cols = {:Sepal length, :Sepal width};
	Eval(
		Substitute(
			Expr(
					Formula(
						If(As Column(__zscore__) < 2, As Column(__abs__))
			Expr(__name2__), char(abs_cols[i]),
			Expr(__zscore__), "Z-score " || char(abs_cols[i]),
			Expr(__abs__), char(abs_cols[i])
ih
	Eval(
		Substitute(
			Expr(
					Formula(
cxu04
you're right, that worked! thanks so much!
