PS_Ato
Graph Builder: Bar style stacked - How to set color theme?
SDF1
Re: Graph Builder: Bar style stacked - How to set color theme?
Hi @PS_Ato,
  There are a couple ways you can do it.
  1. Go File > Preferences > Graphs > Categorical Color Theme (you can then change from JMP Default to whatever you want). This changes the setting globally.
  2. Right click the color in the legend of your Graph Builder, then select Fill Pattern and choose a new color. This changes it just for the instance of Graph Builder that your running (and if you save the script to the data table), but not globally.
Hope this helps!,
DS
PS_Ato
SDF1
Hi @PS_Ato,
Hope this helps!,
DS
