Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Goodness of Fit statistics for GLM Probit Fit: Deviance or Pearson?
Created:
Apr 18, 2023 03:50 PM
| Last Modified: Jun 8, 2023 6:00 PM(1349 views)
Which GoF statistic is best to use (Pearson or Deviance) when the results disagree? Is one better suited for Probit than the other? I'm using JMP Pro 17.0.0
