Georgios_Tsim
Get predicted values or prediction formula log linear model
I am trying with several ways to get the prediction formula or the values in my table after this code and it doesn't give it.
model = dt << Fit Model(
	Y( :RSF ),
	Effects( :BH ),
	LogVariance Effects( :Category & LogVariance ),
	Personality( "Loglinear Variance" ),
	Run(Save Prediction Formula),
		Dispatch(
			{"Loglinear Variance Fit", "Mean Model for RSF"},
			"Fixed Effect Tests",
			OutlineBox,
			{Close( 0 )}
model << Save Predicted;
model << Indiv Confidence Interval( 0.1 );
Re: Get predicted values or prediction formula log linear model
Enhanced log seems to capture these
View more...
// Save Columns: Prediction Formula
Local({obj},
	obj = Data Table("InjectionMolding") << Fit Model(
		Y(:Shrinkage),
		Effects(:MoldTemp, :Screw Speed, :MoldTemp * :Screw Speed),
		LogVariance Effects(:Hold Time & LogVariance),
		Personality("Loglinear Variance"),
		Run
	obj << (:Shrinkage << Prediction Formula);
	obj << Close Window;
// Save Columns: Indiv Confidence Interval
Local({obj},
		Y(:Shrinkage),
		Run
	obj << (:Shrinkage << Indiv Confidence Interval);
View more...
Local({obj},
		Y(:Shrinkage),
		Run
Local({obj},
		Y(:Shrinkage),
		Run
