joh13213
Data Table Panel Size Adjustments JSL
Currently using JMP19.  Is there any way to script panel size adjustments for JMP data tables?  I know I can manually adjust the panel sizes here, but I'm wondering if there's a way to automate it?  Embedded script names aren't shown fully in the left panel.  Thanks!
Re: Data Table Panel Size Adjustments JSL
DataBrowserBox object doesn't seem to have any messages you could use -> you can explore the displaybox structure of the datatable by using Window(dt) << get xml. From that you can get some ideas what you can maybe manipulate to change the width (these can mess some things up, just know that)
wait(1);//demo purposes
Window(dt)[ListBoxBox(1)] << Set Width(300);
There might also be splitter box you could use
