mikedriscoll
Get min / max of selected data
Hi
I would like to know the most efficient way to get the min and max of a subset of a column.   I realize could do a select where(), and actually use the table subset function, and summarize, but I need the script to loop through thousands of columns (unique criteria per column) and I think opening / closing tables via subset is too slow.
I was hoping to do a select where() to select the rows, and then somehow get the selected data into a list, and return the min and max of the list. I've tried several things but haven't had any success. Any ideas?
Here's a simple test script. In this case I would want to return the min = 66 and the max = 70.
clear log();
clear globals();
names default to here (1);
Open( "$SAMPLE_DATA/Big Class.jmp" );
dtData = current data table();
dtData << clear select;
dtData << select where( :height > 65);
column("height") << set selected(1);
Thanks,
Mike
ms
Super User (Alumni) ms
Re: Get min / max of selected data
Try <<get rows where() which should be faster than first selecting rows of interest.
dtData = Open( "$SAMPLE_DATA/Big Class.jmp" );
rows = dtData << get rows where( :height > 65 );
min65 = Min( :height[rows] );
max65 = Max( :height[rows] );
Show( min65, max65 );
min65 = 66;
max65 = 70;
ms
min65 = 66;
max65 = 70;
mikedriscoll
Thank you!  That is exactly the function i was looking for. I didn't realize that "get rows where()" existed... or that you could apply a list to the column and take a summary of that. Very nice.
