archerwin
How to do Zero Defect Sampling using JMP 10?
before there was a template (zds.jmp). But I can't find it anymore for this new version.
How do you do ZDS now?
Thank you!
skyfree
Re: How to do Zero Defect Sampling using JMP 10?
Generally, You can use below formula to calculate the approached sample size:
If you defect rate is p, Beta is 0.05, n = 3/p
