Get a list of open Data tables
I need a command similar to Current data table() in which instead of giving me the name of the active table it gives me a list of all open data tables. What function will do this?
Re: Get a list of open Data tables
I don't know if its because I'm using version 7 but my scripting guide doesn't contain the section mentioned. I did find the answer although its not a single command like I had hoped.
There is a function called nTable() which gives me the number of open data tables and then I can use a for loop to get a list of table names.
table_names={};
for(i=1,i less than =nTables(),i++,insertinto(table_names, Data Table(i)<
mpb
mpb
Search the Scripting docs for "open data tables" and move through the hits. You will find your question answered in a section titled "Getting and using a list of open tables".
table_names={};
mpb
mpb
That's pretty much what the 8.0.2 docs give as a solution.
