RayE
Generate Delta table to calculate deltas between two temp measurments
I have a data table that combines 2 datasets for 2 temperature for multiple units. Each unit is subjected to 20+ tests at 2 temps.
I need to generate a delta table for each unit, that calculate the delta between temp2 - temp1 as shown in table "Data_Table".
I keep getting the same error after an incomplete delta table is generated shown next
the error I get
My data table
here is my code, if any can help I would really appreciate it
allCols = dt << Get Column Names(string);
tpColName = allCols[1];  // Always Column 1
dutColName = allCols[2]; // Always Column 2
testCols = {};
For(i = 3, i <= N Items(allCols), i++,
	Insert Into(testCols, allCols[i])
// 2. Extract Unique Values
Summarize(dt, dutList = By(Column(dt, 2)));
Summarize(dt, tpList = By(Column(dt, 1)));
// 3. Setup Results Table
dt_delta = New Table("DUT Delta Results");
dt_delta << New Column("DUT", Character, Nominal);
dt_delta << New Column("Shift", Character, Nominal);
For(i = 1, i <= N Items(testCols), i++,
	dt_delta << New Column(testCols[i] || " Δ", Numeric, Continuous)
// 4. Robust Calculation Loop
For(d = 1, d <= N Items(dutList), d++,
	currDUT = dutList[d];
	For(t = 2, t <= N Items(tpList), t++,
		p1 = tpList[t - 1];
		p2 = tpList[t];
// This forces a match even if your DUT/TestPoints are numbers
		r1Mat = dt << Get Rows Where(
			Char(Column(dt, 2)[]) == Char(currDUT) & Char(Column(dt, 1)[]) == Char(p1)
		r2Mat = dt << Get Rows Where(
			Char(Column(dt, 2)[]) == Char(currDUT) & Char(Column(dt, 1)[]) == Char(p2)
// Ensure exactly one row found for each point to prevent subscript errors
		If(N Rows(r1Mat) > 0 & N Rows(r2Mat) > 0,
			row1 = r1Mat[1]; // Explicitly take first found row as integer
			row2 = r2Mat[1];
			newRow = dt_delta << Add Rows(1);
			dt_delta:DUT[newRow] = currDUT;
			dt_delta:Shift[newRow] = p2 || " - " || p1;
			For(c = 1, c <= N Items(testCols), c++,
				colN = testCols[c];
				v1 = Column(dt, colN)[row1];
				v2 = Column(dt, colN)[row2];
				If(!Is Missing(v1) & !Is Missing(v2),
					Column(dt_delta, colN || " Δ")[newRow] = v2 - v1
dt_delta << Bring Window To Front;
Edit (jthi): added JSL formatting
Re: Generate Delta table to calculate deltas between two temp measurments
Does not return the row number.  If you change it to:
newRow = nrows(dt_delta);
it will work
11 REPLIES 11
Could you provide the data table?
RayE
Thanks Jarmo, see attached table
it will work
RayE
Thanks Jim, I will the new code, I was getting empty table
RayE
it worked like a charm!, I will try it on a larger dataset, Thank you Jim
RayE
confirmed calc in excel as well, data match.
RayE
Hi Jim, is there a script or feature in JMP that allow me to scale out all numeric columns to include limits; so when I run variability charts, the limits get included . Right now, all graphs are auto scaled based on data only. Thanks
Every column in a JMP data table can have Column Properties set for them.  If you right click on the header of a column, you can then select Column Properties, which in turn will display all of the Column Properties that can be set.  The 2 items that seem to be what you will need are Spec Limits, and Axis.  Once set, they will be used/displayed on all subsequent relevant graphs.
RayE
Hi Jim this may work for for few tests, but I have ~2k tests and it will be hard to do one at a time, is there a way to do script to apply to all tests? thanks
