I recently installed JMP and I think I ought to have set up the license properly. However upon going to through the tutorial I noticed something that I really ought to fix and is unfortunately, not addressed in most newbie guides I can find.
When I clicked the trial Columns and began to cast them I found that apparently, there was not any response from JMP.
I could click and drag, I could double click, I could select the columns and then click the X, Factor or Y, Response buttons and nothing would appear to happen. Confused I eventually hit OK and the graph I had attempted to make was properly generated. This baffled me because it appeared that I had never successfully input anything. I tried again still confused and eventually realized that I would have to resize my window to properly see what my inputs are.
So JMP is working properly over here I just appear to have some strange and functionally disruptive bug that revolves around my screen resolution or something. I wondered if there might be some setting that I had on by default that I ought to turn off. So I looked up some JMP troubleshooting guides and entered my File>Preferences menu only to find the same issue again. Again able to be temporarily solved by resizing my window.
I was a little bit lost, because I can't seem to find this issue when I look it up, and I am not sure I want to go around flipping preference switches in hopes that turning off one of the many settings fixes the issue. As I played around trying to replicate my issues (I am able to consistently update the GUI by resizing it) the GUI would sometimes inexplicably work which just makes everything even more confusing. For instance a selection of "Height" in that tutorial would after a few minutes render inside the Casting box, but when trying again with "Weight" I could wait a good ten minutes and never see an update. The first selection I make in a window seems always to work well but the second selection doesn't always highlight. In another window I used the scroll wheel on the right hand side of the screen only to realize no scrolling was occurring. Clicking on the window again updated the window to render the proper part of the page that had been scrolled to.
There must be some reason that all of these things are happening, Hopefully it is one I can fix. Is this a known JMP issue? (I didn't find any reference to it by an internet or forum search.) Maybe it is some compatibility issue? I am using a Dell Windows 10 Enterprise laptop with an Intel CPU and a very basic Nvidia graphics card.
It would be nice to get JMP to work smoothly, frankly having to constantly update the windows such that they render my tutorial inputs is borderline unusable. I'm not an expert R user and JMP looks like it could save me some time, hopefully with a little fixing it can.
For those who recommend it, I have tried restarting my computer, and I have tried updating JMP. I am using version 16.2.0
Thanks in advance!
