CLSage_IFX
GR&R Report Generation
I am looking for a methodology of how to structure my data table for a GR&R analysis and how to generate that report using JMP.  Currently I've used Galaxy to  create a GR&R report, with testing x number of devices 10x in each test site of my board and then repeat that for y number of appraisers.
Re: GR&R Report Generation
JMP help most likely has the answers for you, this is most likely a good starting point  Quality and Process Methods > Variability Gauge Charts > Launch the Variability Gauge Chart Platfor...
CLSage_IFX
Thank you for your quick response.  I see this is a graphing option.  Is there something in JMP that calculates the GR&R/AV/EV/etc values from my data?
CLSage_IFX
Thank you :)
