Thierry_S
Windows 11 > JMP 19 > Script to Assign Continuous Gradient > Issue with Passing the Gradient Range to the Column Property
Hi JMP Community,
I wrote a simple script to assign a color gradient to continuous-value columns based on the 0.05 quantile of columns values.
dt = current data table ();
scol = dt << Get Selected Columns ();
For (i = 1, i <= N items (scol), i++,
	column (dt, scol[i]) << Format("Fixed Dec", 12, 3);
	low_mark = Col Quantile(column (dt, scol[i]), 0.05);
	high_mark = Col Quantile(column (dt, scol[i]), 0.95);
	if(abs(low_mark) > high_mark, bound = -low_mark, bound = high_mark);
	range_list = {-bound, bound, 0};
	column (dt, scol[i]) << Set Property ("Color Gradient",
										{"Blue White Red", Range (Eval list (range_list)),
										Color cell by value (1)})
While it works in assigning the  correct colors, JMP returns an error when I subsequently edit the gradient manually (see below):
Hence, I need a method to pass the gradient range values without triggering an error upon subsequent manual edits.
Thank you.
Best,
TS
Thierry R. Sornasse
Re: Windows 11 > JMP 19 > Script to Assign Continuous Gradient > Issue with Passing the Gradient Range to the Column Property
You are missing expression evaluation
dt = Current Data Table();
scol = dt << Get Selected Columns("String");
For Each({colname}, scol,
	Column(dt, colname) << Format("Fixed Dec", 12, 3);
	low_mark = Col Quantile(Column(dt, colname), 0.05);
	high_mark = Col Quantile(Column(dt, colname), 0.95);
	If(Abs(low_mark) > high_mark,
		bound = -low_mark,
		bound = high_mark
	range_list = Eval List({-bound, bound, 0});
	Eval(EvalExpr(
		Column(dt, colname) << Set Property(
			"Color Gradient",
			{"Blue White Red", Range(Expr(range_list)), Color cell by value(1)}
		bound = -low_mark,
		bound = high_mark
	Eval(EvalExpr(
			"Color Gradient",
